by LikeaWine
Phone charges Turkey
This may sound a daft question but I am old and technically challenged. If you phone rings when I am abroad and I don't answer it will I be charged. I have turned the VM off ready for my trip. I think I understand that I can use free WIFI … I also need to ensure that I switch the mobile data off...  Many thanks for any help...
Re: Phone charges Turkey
Hi @LikeaWine,
As long as Voicemail is turned off, you won't be charged if you don't answer the call.
If you decide you would like to use your phone, you can fine the roaming rates in our roaming tool.
Have a great trip.
