by AilieC2
Outgoing int'l roaming still enabled?
I have text ROAMING to 150 and have been told my phone is set up to use abroad but when I check call barring the outgoing international roaming is still enabled but have read this shouldn't be? Leave on Monday so need sorted ASAP!
Re: Outgoing int'l roaming still enabled?
You need to call CS to lift international call barring.
by Ace Contributor
HI,
@AilieC2
You need to Get in Touch -with ee and you can do this via live chat opening Get in Touch -page underneath +EE where you can request to remove your international call barring.
@AilieC2  Roaming is not the same as international and premium rate numbers.  One is for calling when abroad not the in the UK “Roaming”. The other is to call none UK numbers abroad and premium rate numbers.  The international and premium rate numbers are chargeable numbers that are not covered via your tariff. Activation of roaming allows you to use your tariff allowance in the EU and if you have one of the new max plans you can use your allowance in 5 other none EU destinations, this doesn’t activate international and premium rate numbers.
EE Employee
Hi @AilieC2 and welcome to the community.
Please do give customer services and they can double check your account to make sure everything is ok for your journey abroad.
Many thanks,
Lee
