by jacqueline0 Established Contributor
On the 4Gmax plan can I call a UK number when we are both in USA
On the 4G max plan can I call a UK number when we are both in USA and can that number call me back if it is not on max plan
Solution
Re: On the 4Gmax plan can I call a UK number when we are both in USA
On a Max Plan you may call a UK no. wherever it happens to be from the US for free.
Not on a Max Plan the other UK no. can call you from US but it will cost them.
6 REPLIES 6
Solution
Hi there @jacqueline0
Thanks for coming here for help.
@XRaySpeX is correct, you will be able to use your allowance in the USA if you're on a Max Plan taken after 10th May 2017.
You can use your minutes, texts and up to 15GB of data.
For anyone not on a Max Plan see our Roaming charges for USA Help page.
Make sure to text ROAMING to 150 before you go to make sure you're all set up to use your phone abroad.
Have an amazing time 🙂
Thanks for the help
Sent from my iPhone
Thanks! You're welcome :)! Glad I could be of assistance.
by Scholarly Contributor
You can actually use more than 15GB of data on a Max Plan as the Fair Usage Policy doesn't apply there (also Mexico, Canada, Australia and New Zealand).
@Leanne_T @jacqueline0
@sully1311: It's moot!
Recent solutions
