by Beno1987
On holiday in the eu but can't ring out?
Hi
im currently in Spain and on a 4gee max plan but it won't let me ring the uk? Can you help
cheers
beno
Re: On holiday in the eu but can't ring out?
@Beno1987
Did you enabled roaming on your account before leaving the UK ?
Are you putting 44 or +44 instead of the 0 at the start of the number?
Do do you have a signal on the device?
have you tried restarting the device since you got there ?
by Beno1987
I have activated it a few times but every time I seem to go abroad again it's the same thing.....won't let me ring out.
the 3G is working as I'm using that to message now.
tried the +44 just not to no avail.
maybe it needs to be activated again. Has this got to be done every time before going away?
many thanks
@Beno1987   When is roaming has been enabled on your account it stays in enabled and doesn't need to be done every time you go abroad.
EE Employee
Hello @Beno1987
It sounds like your international bar may still be active.
I'll send you a Private Message with a link to our Chat Team.
They'll be able to lift the bar for you.
Have a fab time away!
Thanks - Karen. Smiley Happy
