by amandascott2007 Investigator
On holiday in Croatia and not been able to send SMS to the UK - Samsung A3
Arrived in Croatia yesterday, Samsung A3 detected new network, roaming was switched on before leaving UK. Cannot send SMS but can receive them. Checked the Message Centre number is correct and also tried manually connecting to a different network, still the same. Turned phone off and on, no change.
I can make calls to the UK no problem.
Can someone please help, cannot find how to start live chat.
Solution
Re: On holiday in Croatia and not been able to send SMS to the UK - Samsung A3
Hi @amandascott2007
Welcome to the community, I hope you're having a lovely time in Croatia.
It's on my list of places to visit to check out the setting for King's Landing from Game of Thrones. 🙂
Could you try doing a manual network search and try using a different Croatian network?
Device type Steps
Apple Settings > Carrier > Toggle Automatic OFF
Android Settings > More Networks > Mobile Networks > Network Operators > Tap OK
Windows Settings > Mobile Network > Network Selection > Tap on start manual search
Hopefully, you find one and your texts work better.
Let us know what happens.
Chris 🙂
by Ace Contributor
Hi @amandascott2007
Try 00447xxxxx before number you call or text.
I have just checked a message that failed to send and it went to +447 etc, etc. Surely I don't have to edit every number that I want to send a text to 00447 etc?
Solution
Hi @amandascott2007
Device type Steps
Chris 🙂
There are 8 networks available, tried all of them, some do not allow me to connect and the ones that do I have the same problem, can receive texts but not send or reply. Frustrating now as family members are getting concerned.
Can I call EE free from Croatia using roam like at home?
Thanks for trying that, @amandascott2007
Yes, Croatia is covered under EU roaming.
