by SuperFuzz Investigator
On a monthly EE plan, is data useage, calls and texts free when I am in Iceland?
So I am on a monthly plan with EE, and when I went into the shop to ask if it was free/no additional charges for texts, calls, and data useage when in Iceland - the guys in the shop said there would be. But online it seems to say that there isn't, that it is free or billed as if I were in the U.K, as long as I don't go over my monthly limits in Iceland. Which is true? Thanks. Also, to use roaming do I need to do anything specific on my phone when in Iceland?
Solution
Re: On a monthly EE plan, is data useage, calls and texts free when I am in Icel
Hi @SuperFuzz
Iceland us included in EU roaming as per EE roaming guide.
Just make sure you text ROAMING to 150 to ensure its set up on your account.
8 REPLIES 8
Solution
Hi @SuperFuzz
Do I do this before I go to Iceland or when I get there? How can I check my data useage and bill while I am there?
@SuperFuzz
Text before you go/now so you can sort out any problems before you travel.
You can check your usages via the phones in built data app, via the EE app or EE website.
I text ROAMING to 150, and it said 'Good news, your phone is already set up abroad - just restart your phone when you arrive and you should be good to go.'
Welcome to the community, @SuperFuzz 🙂
That means that you're good to go. 🙂
You can see confirmation that you can use your normal calls, texts and data in Iceland on our EU Roaming help page.
Have a brilliant time.
by Skilled Contributor
Skilled Contributor
Might be imperative to ask what EE store is giving wrong Information out and retrain them ASAP.
*Easiest way to find info is*
EE HELP SEARCH https://ee.co.uk/help/help-new
Phone +447953 966 250
Live Chat/Complaints https://ee.co.uk/help/help-new/make-a-complaint
Complaints Code of Practice https://ee.co.uk/help/help-new/safety-and-security/protecting-your-information/complaints-code-of-practice
It was the Epsom store. Just one more quick question, is there any way to buy additional data allowance? Or do I just run over and get billed? The guys in the store said I couldn't buy any data add-ons/extra data, that I would just run over, but just thought I would check here!
Skilled Contributor
See data left and buy additional here http://add-on.ee.co.uk
You cant run over, you must buy a data add-on. That Epsom EE store sounds pathetic and definitely needs trained - these are EE basics to know for staff.
