Highlighted
On £15 Data Pack
With regards to the £15 Data Pack which I bought in London, if I go to Europe and use it there, will the same data and call rates apply as though as I am using it in London ?? THANKS
Highlighted
Solution
Re: On £15 Data Pack
As I said nothing will be more expensive than London. In fact calls & texts to EU nos. will be cheaper.
  • Your data allowance will be used in the same way as in London (up to 15 GB / month which only 1 £30 pack exceeds).
  • Calls & texts to UK nos. will be exactly the same as in London.
  • Calls & texts to EU nos. will be included in your pack unlike London where they were charged.
  • Calls & texts to non-EU nos. will be charged as they were in London.
Highlighted
Basically yes. In fact the call & text rates for calling EU nos will be even cheaper than from UK as these would be International calls when made from the UK & would not be included in your pack allowances.
Highlighted
Thanks for the reply. However, would like to seek clarifiaction in terms of the data & call rates when using the mobile (the said pack which bought in London) in Europe. When surf internet, WhatApp, make call in Europe (i.e. call within Europe or call from Europe to UK), will it be more expensive when compared to using it in London?
Sent from my Samsung Galaxy smartphone.
Highlighted
Solution
Highlighted
Hi @eric99,
Welcome to the EE Community. Smiley Happy
Did @XRaySpeX's great answer give you all the information you needed?
Recent solutions
