by Addyp Investigator
Off to turkey
Hi im off to turkey next weekend. Im wanting to use my internet while im there. Is there anything i can add on to my contract to do this so i dont get loads of charges. Thanks
by Profile closed
Not applicable
Re: Off to turkey
You will need to get the EE Travel pass add-on at £6.00 per day to use data whilst in Turkey, full details can be found here.
Be careful though as the EE Travel pass will re-new automatically every day even if you don't use any data.
EE Employee
Re: Off to turkey
Hi @Addyp and welcome to the community.
Please see the advice given above.
Many thanks,
Lee
by Ace Contributor
Re: Off to turkey
Shouldn't that be that you're only charged on the days you use data when in an included country?
EE Employee
Re: Off to turkey
Hi @chistery,
You are indeed correct.
Opt-in once and you’ll only be charged on days you use data in an included country, so there’s no need to remove it when you get back to the UK.
The Travel Data Pass daily charge will automatically trigger each day you use mobile data on your phone when you're abroad.
Your phone will use data if you have apps that automatically update in the background. This will trigger the daily charge.
The daily charge is:
  • £4.80 a day in the USA and Canada
  • £6 a day in Australia, China, India, Mexico, New Zealand, South Africa, Thailand, Turkey and UAE
Many thanks,
Lee
