by Valenni
Number withheld when roaming.
Over the last 3 months, I noticed people were not returning my calls when I was in Dublin.
It transpires that when I am roaming in the Republic of Ireland, my number is withheld when calling back to the UK. As soon as I cross the border onto my home network, my number is no longer withheld.
Any ideas?
(I-Phone 7)
by Ace Contributor
Re: Number withheld when roaming.
Hello @Valenni this has been reported before and appears to be an issue with roaming on the ROI network:
https://community.ee.co.uk/t5/Roaming/No-caller-id-when-dialling-from-Abroad/m-p/658410#M17453
Was there another network you could use by performing a manual network search? Apart from the inconvenience of showing as witheld when roaming it should have no other effect on your account.
Hi @Valenni
Welcome to the community.
Please let us know how you get on after trying another available network:-
  • iPhone – Settings > Carrier > Toggle Automatic OFF
  • Android – Settings > More Networks > Mobile Networks > Network Operators > Tap OK
  • Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Chris 🙂
