by Johnwjohnw Investigator
No signal in Portugal
Hi, phone had signal for half an hour at the airport, I bought a £20 internet booster, ten minutes later no signal and that's still the case 5 hours later. Try connecting manually to Vodafone and it says SIM won't let me. Got good signal on my work blackberry. Ideas??
Thanks!
Re: No signal in Portugal
Do you have roaming activated on your account?
If not you will need to ask EE CS to activate this service.
Yes.
Hi @Johnwjohnw
Welcome to the community 🙂
What kind of handset are you using?
Is it a pay monthly personal or a pay as you go EE SIM card you are using?
Are you able to receive calls and texts?
Richard
