by chris27
No service in Tenerife
Hi, i have been in Tenerife for 3 days now and keep getting the same message; Selective Service (EE) unavailable. Please help!  many thanks
EE Employee
Re: No service in Tenerife
Hi @chris27 and welcome to the community,
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on.
Please also can I get you to try and dial a friend or family member using format of 00447********* and try using data.
Did this work?
Many thanks,
Lee
by chris27
Hi Lee, sorted! Just searched networks and it found EE. Simple i know but I'm no expert with mobiles. So thank you so much for you're help.
EE Employee
Hi @chris27
Glad you are now sorted 🙂
Cheers
Lee
