by shonac Investigator
No network in USA
I'm currently in the USA and cannot seem to connect to any network. I have enabled roaming on my ee account, reset network settings, tried connecting manually etc. Any other ideas?
Thanks!
S.
EE Employee
Solution
Re: No network in USA
Hi @shonac
As the suggestions have not worked, please pop to the live chat link.
This can be found in your Private Messages.
Our customer service team will be able to assist with your issue.
The link will be active from now till 8pm (UK TIME).
Let me know how you get on.
Many thanks,
Lee
EE Employee
Hi @shonac and welcome to the Community.
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on.
Do try and turn to 3G only signal.
Please also can I get you to try and ring using format of 00447*********
Also, please let me know If you are using an EE personal or business account?
Many thanks,
Lee
Hi Lee,
Thanks for the quick reply.
I have changed the phone to 2G/3G only.
A manual search gives me three  networks. Each one gives error message of "you cannot connect to this network at this time" message.
I can't call any numbers as have no network whatsoever.
I'm a personal customer.
Not sure if it makes any difference but it's an LG G3 (my new LG died last week so using the old one!) running Android 5.
Thanks!
EE Employee
Solution
Hi @shonac
Many thanks,
Lee
So after contacting customer services my issues have been resolved. Apparently roaming wasn't enabled on my account after all despite my online account showing that it was switched on.  Thanks for your help in getting this resolved.
S.
EE Employee
Glad your sorted @shonac
Enjoy the U S of A 🙂
Many thanks,
Lee
