by cinek2 Contributor
No internet
im in the USA and for some reason today I have no internet. Can make and receive calls but that's about it. Called support but they weren't much help. In fact after following the instructions I ended up losing reception completely for over an hour. They also suggested switching from at&t to T-Mobile but that's coming up as forbidden and even when I try to switch it errors out. Any ideas what I can do? Can't even get a cab
12 REPLIES 12
by nikork
New Member
I am using my phone abroad (San Francisco, USA) and my data just stopped working
I a m UK based EE customer with a package that allows me to use my phone and full 4G coverage in the USA. I am in the USA now. Data was working fine for the first couple of days with a strong 4G signal. Since today my phone only shows a 3G connection and doesn't actually give me any connection. Can anyone help? Data roaming / allow 4G are both switched on on my iphone. I have restarted my phone several times.
by Harrisg66 Investigator
Re: I am using my phone abroad (San Francisco, USA) and my data just stopped wor
You are not alone I have the same issue I am in LA - non of the EE Roaming has been working all day today - called customer services and raised a ticket - we have 3 of us here and none are working - lucky I do have an ATT phone so i do have data which also proves its an issue with EE and not a local cell issue...  you can try changing to TMobile and see if that works - Mine just started working again I am now manually on TMobile for data and voice all working again finally....
Re: No internet
This appears to be a US Wide issue mine has been down all day today I raised a support ticket with the EE team earlier
Keep trying to connect to TMobile if you can mine came back on just now
Wife's phone still not working
Re: No internet
Thanks, couldn't pick T-Mobile as it was saying forbidden. Even when I tried to connect it would error out. I went and bought an at&t SIM and am using this now. Done with EE tbh. Too many issues at this point. Wasted half a day with support instead of enjoying the holidays. Business support is really bad. Office closed.... Time to move to 3 and not have to pay extra for something I can't use. Will be calling about a refund as I paid £40 for the data add-on too 🤦‍♂️ as the £4 per day option would not work
Re: No internet
Hi @cinek2
I know that you've said AT&T didn't work and T-Mobile didn't work, we're you able to connect to any other US networks?
Does the issue still happen when you use your EE SIM?
Re: No internet
nope, AT&T was the only option, all other networks were showing as forbidden
EE Employee
Re: No internet
Hi @cinek2
I understand your frustration with these issues, we have passed over a couple of examples to our roaming team for investigation.
Many thanks,
Lee
Re: No internet
Hi Lee
what was the outcome of this "investigation"? I found other posts from last year where EE was "investigating" and no updates have been provided after that
Re: No internet
Hi @cinek2
If you're still having problems and are unable to connect to another US operator, please contact our technical support team.
If you're an EE pay monthly customer, I recommend logging into your My EE account on your phone's browser (not the app) or a computer.
Once you're logged in, a chat window will pop up when an advisor is available.
If you can't get in contact with chat or have a different account type, please get in touch from an alternative phone.
Thank you.
Re: No internet
Back in the UK now. That doesn't answer my question tho. I called technical support when I had this issue and they couldn't help. I'll ask again, how did the investigation go? Or is this just a BS answer you lot use to get us off your back knowing damn well we'll be back in the UK soon. Flipping joke!
EE Employee
Re: No internet
Hi @cinek2
This is not something we have had sight of and we have seen no further examples of issues affecting the USA.
Many thanks,
Lee
Re: No internet
Not sure if you're serious or just joking at this point
