by 1alisonp Investigator
No data roaming on htc one m8
Home or abroad I can't get mobile data. Only time I can access internet is when I'm logged in to hotel website. Have full bars indicating signal but no WiFi. What's not working?
Solution
Re: No data roaming on htc one m8
Sorry, not very techy. WiFi is the problem. On path SIM only. Worked ok on my prev phone but not this one. Roaming is switched on. Thanks
@1alisonp  Is this WiFi or cellular data. Because you say cellular data then you go on to say WiFi.
Wifi has nothing to do with EE.
Cellular data is you data allowance that comes with your contract/payg top up.
Are you contract or payg ?
where are you ?
have you enabled roaming on the device if you have this option?
Solution
In republic Ireland at moment, but it happened whilst in Spain & when I'm home in the UK.
Think I've cracked it.  APN details incorrect but found this which has solved the issue.
https://www.teamknowhow.com/discover/discover/ee-apn-settings#Android%20APN%20settings%20for%20EE
Hi @1alisonp,
Thanks for the update,
I'm glad you were able to find a solution.
