by KirstyCalvert Investigator
No connection in Majorca
Landed in Majorca last night zero mobile data or service. Roaming is on as I travel a lot and was in Holland last week and at the airport on landing I had no problem. I have restarted my phone got 4G and 1 bar for a few seconds then it disappeared. I reset network settings also made no difference. I have my carrier set to automatic selection but I have no idea what else to try and I cannot call as have no network help please thank you.
15 REPLIES 15
Re: No connection in Majorca
Hello there @KirstyCalvert
Can you try and manually connect to a network as below;
  • Phone – Settings > Carrier > Toggle Automatic OFF
  • Android – Settings > More Networks > Mobile Networks > Network Operators > Tap OK
  • Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Let me know how you get on.
No only three networks came up and non will give me network.
Thanks for trying @KirstyCalvert
Is your roaming showing as set up in your My EE account?
To check this, log into your My EE account online and go to Menu > Manage Device > Roaming
If this is not showing as ticked, can you activate this within your My EE?
This can take up to 24 hours to update for you.
Let me know how this goes.
Yes roaming is set up it worked on Friday when I was in Holland and Thursday I’m germany and also worked last night at the airport but 20mins away I have nothing
Hi @KirstyCalvert
What phone are you using?
Can you receive calls at all?
It’s an iPhone X and no I have no signal at all
Thanks @KirstyCalvert
Can you try the settings below and see if this works for you.
Go to Settings > Mobile Data > Mobile Data Options > Enable 4G > Turn this off.
Then try and connect to a network again in the Carrier Settings.
If this does not work, can you try a network reset.
Go to Settings > General > Reset > Reset Network Settings.
This will remove any saved WiFi passwords.
Let me know if this works for you.
First option didn’t work so I did a second network reset and I got 4G with one bar for about 30 seconds then back to nothing.
In this case we are going to need this looked into further for you.
You would need to call us from an alternative phone so we can help you get this sorted.
ok Thankyou my other phone connected to my account appears to be working
No problem @KirstyCalvert
Hope you have an amazing time in Majorca 🙂
No that is not working either I’ll just make do with WiFi as we are only here a few days I tried to call and it disconnected.
Hi @KirstyCalvert
Does your other number receive calls?
It appears to be that I am in a signal black spot at the hotel but my partner who is on Dutch T-Mobile has full signal.
I have sent you a private message on here to get some details.
