by Purfleet Investigator
New york only 2g
I am on the new max plan but arrived in new york and can only connect to 2g.
can some please let me know how i can get faster speeds
by Ace Contributor
Solution
Re: New york only 2g
This is the site I was looking for...
https://willmyphonework.net/
So European OnePlus 3T, no 4G on T-Mobile or ATT.
8 REPLIES 8
Try choosing a network manually.
@Profile closed can probably help as he travels to the US.
by Profile closed
Not applicable
@Purfleet You can roam using either AT&T or T-Mobile when in the USA and both should be able to provide 3G and 4G.
What handset are you using?
As @Northerner mentioned, try an manual network search and select either of those 2 from the list of available networks.
Generally, EE handsets will default to T-Mobile but you can also use AT&T which is generally better in big cities.
by Ace Contributor
What phone are you using @Purfleet?
Hi all
One plus 3t
3g came up last night and speeds we're okay but back to edge now.
I tried to manually select at&t but it said that I can't register on the network
Cant understand why I can't get 4g in a city like new york
by Ace Contributor
I don't think the European Oneplus 3T will work in the USA on 4G due the LTE bands the phone supports. Time to upgrade to the OnePlus 5?
by Ace Contributor
Solution
A phone was made in 2016 that didn't support the us network?
3g will do, edge is unacceptable.
by Ace Contributor
Back in the day when OnePlus phones were better value, they made different version, US, Europe/Asia and China. It meant cheaper hardware for each phone but they didn't work globally.
Now the price has been increased quite a lot, they have one version that works in most places.
Edge is a small step up from 2G, but may be the best you get with such an old phone! Robot Frustrated
