by edmondson20
New Member
Network
Im in berlin in europe and cant make calls, send texts or use data although i can recieve them. Ive gone trough troubleshooting and dont know what it is. It says there is no network
Re: Network
Hello there @edmondson20
What device are you using?
Do any networks show in your device settings?
Please see our Roaming, what to do if you're having problems abroad post>
This post provided hints and tips for you to try to get connected when Roaming.
Hope to hear back from you soon 🙂
