by Ashraful03
Need to lift my call bar setting as I'm abroad.
Need to lift my call bar setting as I'm in Thailand and need to make some urgent calls. How do I do that?
Solution
Re: Need to lift my call bar setting as I'm abroad.
Hi @Ashraful03
You need to log into your online account, then Menu - Manage your device. You need to ensure roaming and international calls are activated.
EE roaming costs for Thailand can be found here.
Solution
Hi @Ashraful03
