Highlighted
by Investigator
NO signal in Italy
hi there,
I travel to Italy very often, always with the same mobie/plan and I have never had issues at all. When I arrived I had no troubles but the day after I have completely lost the signal. I cannot make/receive calls and obviously no internet.
I cannot even contact 150. What shall I do?
Highlighted
by Ace Contributor
Solution
Re: NO signal in Italy
Hi @Farida9 Sounds more like a handset problem. Is roaming enabled and have you tried turning powering it off and on again?
6 REPLIES 6
Highlighted
by Ace Contributor
Hi @Farida9 Have you made any changes to your plan recently?
Have you tried a manual network search? what happens when you select a network?
Highlighted
by Investigator
The only unusual thing is that before going to Italy I spent a couple of days in Switzerland but there I had no problems at all.
It says "Error while searching for networks"
Highlighted
by Ace Contributor
Solution
Highlighted
by Investigator
Yes roaming was enabled. I have just tried to turn it off and on again and it worked !!!!! Thank you for the suggestion
Highlighted
Good Morning @Farida9.
Welcome to the community 🙂
I'm glad you're all sorted following @chistery's advice!
I hope you have a great time in Italy.
Jon
Highlighted
by Ace Contributor
@Jon_K beat me too it, what he said! Robot Happy
Recent solutions
