by dean4161
My s9 data is not working
I have recently upgraded to a Samsung s9 and the data is not working
by Ace Contributor
Re: My s9 data is not working
Hi @dean4161
Welcome to the Community,
have you checked that mobile data is switched on ?
by Ace Contributor
Are you roaming or in the UK ?
Did you enable your a/c for roaming before you left?
Can you make calls & texts from aboard?
