Highlighted
by Investigator
My roaming not working as expected: cannot receive or make calls, or send sms
I am on a PAYG contract and have bought packs recently (i.e. my account is not suspended). The option to enable roaming is not available in MyEE (probably because I am a PAYG customer). I am currently in Germany and I cannot:
- Make phone calls;
- Receive phone calls;
- Send text messages;
- Listen to my voice mails.
I receive notification text messages when people call me but do not leave a voice mail message. When people leave voice messages, I receive a notification to call my voice mail (which I can't - I am told that calls to that number are barred from my phone).
I have tried to contact support through the live chat function but I only get a message that live chat is available Mon-Sun 8am to 11pm.
This is rather frustrating and it's concerning that I can't listen to my voice messages. Can someone please help me get the correct configuration to use my phone abroad?
13 REPLIES 13
Highlighted
Re: My roaming not working as expected: cannot receive or make calls, or send sm
Hi @NH4,
Pay as you go accounts are automatically set up to use abroad.
Does your phone show that it is connected to a local network?
What happens when you try to make a call?
Was your phone working as normal in the UK?
James​​​​​​​
Highlighted
by Investigator
Hi James
Thank you for your response. To answer your questions:
- Yes, my phone is connected to the German Telefonica network (O2). Also, text messages with notifications from EE are delivered to the phone, so it is clearly on the network.
- When I try to make a call *from* the handset to a number, a voice message says “calls to this number are barred” or something to the effect. This includes the voicemail number, so I can’t listen to all the messages that have now piled up.
- When I use a different ‘phone to call my EE number, it goes straight to voicemail. If a message is left, a voicemail notification appears on the EE phone. If no message is left, a text messages notifying me of the missed call is delivered to the EE phone.
- The setup works flawlessly when I’m in the UK.
I hope you’re able to help resolve the mystery. At the very least I have to urgently deactivate voicemail to stop people from leaving messages that I can’t listen to.
Kind regards
Nils
Highlighted
Thanks for confirming this @NH4
Are you able to manually connect to a different network to see if this resolves your problem?
Do you currently have an active pack?
What phone are you using?
Speak shortly,
Katie 🙂
Highlighted
by Investigator
Hi Katie
Thank you for your message.
- Yes, I have manually changed to Telekom but the problem persists. (And I have also restarted the phone several times).
- I have a £15 data pack.
- The phone is a Blackberry Q5.
Thank you for your help.
Highlighted
Hi @NH4
I have sent you a private message for further information.
Speak soon,
Katie 🙂
Highlighted
by Investigator
I having exactlt the dame problem.
I have an active pack. But unable to do anything.
Please help
Highlighted
Hi there @Danokotl
Thanks for coming here.
Did you use the SIM in the UK to make a call or send a text before travelling abroad?
Where are you roaming?
Speak soon 🙂
Highlighted
by Investigator
Hi Leanne,I'm currently in German & the SIM has been in my phone now since i landed, 24hrs ago.Sent from my Samsung Galaxy smartphone.
Highlighted
by Investigator
Hi Leanne,
no, i hadnt used the sim in the UK
Highlighted
Hi @Danokotl
Thanks for the quick reply.
Did you use the SIM in the UK to make a call or send a text?
Pay as you go SIM cards do need activated on the EE network before they can be used abroad, this can be done by making a call or sending a text whilst in the UK.
Highlighted
Just seen your reply @Danokotl
Thanks for letting me know.
The SIM would need to have been used within the UK as above.
Once you return and use the SIM on EE, your pack will activate, and you will be able to use the SIM.
Thanks.
Highlighted
by Investigator
That's not possible for 4 weeks.
What can I do?
Highlighted
Hi there @Danokotl
If you get in touch with our Tech Gurus from another phone on +44 (0) 7953 966 250, they will see if there is anything they can do to help.
Thanks.
