by SKingsley1
New Member
My roam further is not working in USA
So before we came to USA I set up Roam further for all 5 of us. I got text messages confirming it was all set up.
Turned on phone in USA. It doesn't work. But my children's phones do and they are linked to my account.
I can't even phone EE.
I've restarted my phone, but without being able to speak to EE I don't know what else I can do....
Re: My roam further is not working in USA
@SKingsley1   Login to your EE online account and under mange this device enabled roaming also enabled call abroad and premium rate numbers then restart the device
Hi @SKingsley1
Welcome to the community, I hope you're having a brilliant time in the US so far. 🙂
Please follow @Chris_B's advice and check your roaming status in your My EE account.
If it's already set up, please try a manual network search and select an available network:
Device type Actions
iPhone Settings > Mobile Data > Network Selection > Turn off Automatic
Android Settings > More Networks > Mobile Networks > Network Operators > Tap OK
Windows Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Keep us updated on how you're getting on.
