by K03Harding89 Investigator
My phone won't call or text? I'm abroad, but it was working on the first day?
9 REPLIES 9
by omawill Valued Contributor
Valued Contributor
Re: My phone won't call or text? I'm abroad, but it was working on the first day
Have you gone over your usage limits?
How would I know if I had? I'm unlimited texts and calls so didn't think I could!!
Valued Contributor
Have you made sure that your phone is set up to roam whilst aborad, are you also on PAYG or Pay monthly
Well it was working the first day!! I've only had it a week, so don't know if set up for sure! I'm a pay monthly customer!
Valued Contributor
To check you're set up before you travel, text ROAMING to 150. Did you do this before you left the UK?
There may be some problems with your account if you have only had it a week, sometimes a few things just need setting up. If you can hold out until 8am UK time tomorrow (when I think EE opens again) You can contact them here
If you are abroad however you may have to use the alternate contact numbers as opposed to 150.
When I was with Three my services worked the first day but not the second (Whilst in Germany) It was a simple case of me needing to change which network I was using by default (As there isn't a Three mast where I was) It could also be this.
Thank you so much, I'll try to contact them tomorrow 😊
Valued Contributor
No problem, I hope you get the issue sorted!
Come back here if you need any more help; tell us if you got the issue resolved 😄
Also, have a great time abroad!
by Ace Contributor
@K03Harding89
Try manually search network select available network and turn off automatic network search as you said it was working before.
Turn of your phone and then on back and try again.
Many Thanks
Hi @K03Harding89,
Thanks for joining the EE Community.
Did you try selecting a different network as suggested by @tahirmian?
- James
