by immortalmk
My outgoing calls from Bulgaria to UK are restricted?
7 REPLIES 7
Re: My outgoing calls from Bulgaria to UK are restricted?
@immortalmk  Did you activate roaming on your account before leaving the UK ?
by immortalmk
I have roaming. I can use date. I can receive calls.
Hello @immortalmk
Are you with us on an EE personal contract?
I will see what we can do to help 🙂
by Kollerp Investigator
Hello I have the same issue also currently in Bulgaria. Please can you help?
@Kollerp  If you have a working signal on the device you only need to enable international and premium rate numbers you can do this yourself by login to your only account.
Ok thanks how do I do that?
Get Outlook for Android
Hi @Kollerp,
Thanks for visiting the EE Community.
You can enable international calling by logging into My EE and selecting Manage device from the menu.
Hope this helps.
