by Why1
My international roaming package is not working I can’t contact EE help?
I bought a package to cover my phone calls and txts while in USA.  O n arrival I can only txt I cant make calls, I can’t even call EE? Any advice please?
Solution
Re: My international roaming package is not working I can’t contact EE help?
@Why1 : If you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150?
Often just rebooting the phone is the simple remedy. Otherwise try logging into your MyEE account online & go to Menu / Manage Device / Roaming Abroad and also Call Abroad and Premium rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
PAYG is auto enabled for roaming. You don't need to & can't do any of the above.
Solution
by Why1
Thank you, I chatted with agent following your advice and ended up switching off and on again ethic seems to have done the trick. Classic solution:/ !
Glad you got this sorted @Why1
Have a great time 🙂
