by Lisath1972
My galaxy s6 won't let me txt while abroad but I can make calls and receive txt
While abroad my galaxy s6 won't let me txt anyone but I can receive txt and also I can make and receive calls. This as happened since it was sent for repair to the repair centre before then it worked fine
Re: My galaxy s6 won't let me txt while abroad but I can make calls and receive
Hi @Lisath1972,
Welcome to the EE Community.
Have you tried selecting a different network manually in case it's a local network issue?
James​​​​​​​
by Lisath1972
Yes I've been on all sorts of different networks and still doesn't let me txt but I can make calls
Hi @Lisath1972,
Can you try turning off 4G in your mobile network settings and let me know if that fixes the issue?
