by Viki913 Valued Contributor
Valued Contributor
My free EU roaming is not working
Hi guys,
I have a big problem, I'm currently in Hungary (EU), I sent a ROAMING message to 150, which said my phone is already set up to use abroad, just need to restart when the roaming is on. When the plane landed, I switched my phone on/off/on, tried everything, but it still says "no service", while everyone else was able to use their phone.
I'm going to be away for 3 weeks, and I'll pay for my contract, which I won't be able to use? What can I do? Please help me
Viktoria
Re: My free EU roaming is not working
Hi @Viki913
Thanks for dropping by the community.
As you checked roaming is set up, your phone should be able to connect.
Could you try the below steps and get back to me with the results?
Try re-booting your device
Try turning 4G off in ‘settings’
Do a manual network search in ‘settings’:-
  • iPhone – Settings > Carrier > Toggle Automatic OFF
  • Android – Settings > More Networks > Mobile Networks > Network Operators > Tap OK
  • Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
You can see more help on our What to do if you're having problems abroad supporting article.
Please let me know how you get on.
Chris 🙂
