by jousingemail Investigator
My ee sim has no service in New Zealand?
Just got to NZ. EE sim just says no service. Have tried turning 4g off and made sure roaming is on but no luck. Any help? I did cancel my plan before I left. So sim (I assume) has just gone back to pay as you go. But having trouble on the app and website when i try topup or veiw plan options.
Please help! need to receive messages from here.
Thanks!
Jo
7 REPLIES 7
Re: My ee sim has no service in New Zealand?
Hello there @jousingemail
Welcome to the community.
Are you able to manually select any other network in your network settings?
Did you transfer to pay as you go when you were in the UK?
Thanks, Leanne.
Do you have credit on your SIM? Roaming in NZ is chargeable.
It used to be pay as you go. Then I changed to a plan about a year ago, cancelled the plan just before I left. So I'm just assuming it's back to pay as you go. Although it won't let me top up on app or website. So maybe not?
Sent from my iPhone
If you cancelled a contract then your SIM will have been deactivated. You can't just assume it went to PAYG unless you asked for it.
so to reactivate it would be to call EE?
Jo
by Ace Contributor
Hello @jousingemail when you cancel a PAYM account the number is disconnected unless you also:
  • Request to move the number to PAYG.
  • Port the number to another network using a PAC.
When a number is disconnected it is put in quarantine ready to be recycled at a later date. It is not normally possible to retrieve a number after it has been disconnected.
Have you tried ringing the number? If you hear a continuous flat tone or 'you've dialed an incorrect number' then the number has been disconnected.
Only customer service have access to accounts to check if it can but it can not be guaranteed:
http://ee.co.uk/help/get-in-touch
EE Employee
Hi and welcome to the community @jousingemail
Please do get in touch with customer services as they will be able to see what has been requested when disconnection took place.
Let us know how you get on.
Many thanks,
Lee
