by Jaydenm18
New Member
My data roaming is on but I can’t call or text and I need make important calls
My data roaming isn’t working and it says it’s on and I’m in Greece and I need to make important calls to the uk ASAP
Re: My data roaming is on but I can’t call or text and I need make important cal
Hi @Jaydenm18
There are many threads with the solution. You need to log into your online account then menu - manage your device and activate international calls and roaming.
Good Morning @Jaydenm18.
Thanks for coming to the EE Community.
Have you been able to check if both roaming and international calls are active in your My EE Account?
If they're already active, can you try manually searching for another network?
I can guide you through this if you let me know which phone you're using 🙂
Jon
