by Mike_br
Mobile data does not work
Mobile data does not work, does not seem to connect, the Sim card is new.
My mobile data are connected and roaming access too, I already reboot the device, I removed the chip but nothing worked. I'm in Brazil
7 REPLIES 7
Re: Mobile data does not work
@Mike_br  Did you enable roaming on your EE account before you left the UK ?  This is fine by calling customer services or texting ROAMING to 150
and or
Have you purchased an add on as you can not use your EE allowance while there.
@Mike_br: Did you activate roaming on your account before you left UK?
A new SIM? Had you used it first in UK? Did you activate it there?
Can you make and receive calls and texts?
by Mike_br
Do not activate roaming before, just started using the chip here in Brazil and do not know how active roaming
by Mike_br
I did not use it in the UK, I only activated it here in Brazil
EE contract SIMs must be activated while on EE's network in UK.
by Mike_br
Can not activate now? Only in the UK?
@Mike_br  You can not activate a SIM card on a roaming network it has to be connected to the EE network directly. Your account is not setup for roaming and it can not be until the sim is active and because it’s not activated you can not activate roaming.
