by Sebastianciuba
Mega plan use plan in mexico
Hi I in Mexico and I have max plan when I ready my plan Opcion I can you my phone with no extra cos but when I switch the phone in Mexico I get to message:
Welcome to Mexico. Text TRAVEL to 150 to get a massive 500MB of daily data for a fixed £6.00 a day while you're there. Opt in once and you'll only be charged on days you use data abroad in an included country. For full details, click add-on.ee.co.uk/traveldata for free (check data roaming is ON).
Otherwise, you can choose a standard data add-on from £5 for 50MB. Click add-on.ee.co.uk for free to buy.
For the best possible network coverage please make sure your handset can automatically select a network. If you need help to do that, go here: http://ee.co.uk/help/phones-and-device
and
Hi again. Calls cost £1.80/min to make or receive, texts 60p and pic msg 50p each to send. Call +447953966250 for Customer Services (£1.80/min) & 112 in case of emergency. Have a good trip!
Re: Mega plan use plan in mexico
Hi @Sebastianciuba
Have you logged into your online account to check roaming is activated.
Mexico is only covered under Max plans purchased or taken out after the 10th May 2017.
by Sebastianciuba
I bought my plan 14/08/2018
Wysłane z iPhone'a
Hi @Sebastianciuba
Thanks for posting on the community.
What does your plan show as in your My EE account?
Also, are you able to make and receive calls and texts?
Hope you're having an amazing time.
