by Jade24
Max plan
I go to America from the 8th-22nd May and have heard about the EE max plan how do I go about getting it? What does it include? And how much is it?
I currently have a sim only contract which includes unlimited texts and calls and 20gb of data a month.
Solution
Re: Max plan
EE no longer do MAX Plan SIM-Only. You could buy the Go Further Roaming Add-on for 6 months @ £10 / month to give you the Max plans roaming benefits of including USA & 4 other countries..
Solution
Re: Max plan
by Jade24
Re: Max plan
Thanks for helping if I bought it for month to last for the 2 weeks I am in America what would I get data and calls wise? I need it mainly to keep it touch with family that’s all. Thanks again!
Re: Max plan
As i said & that article says you must buy it for at least 6 months. It's a roaming add-on to your existing plan. So you continue with your existing allowances, except when roaming you may only use at most 15GB data per billing month.
