by Cathliamluke
Max plan
Just checking but if myself and my husband are both on max plans and we are both in America can we phone each other with no charges?
by Ace Contributor
Solution
Re: Max plan
Hi @Cathliamluke
Yes you can call and text each other without any charges if you are on max plan.
https://shop.ee.co.uk/price-plans/paymonthly
by Ace Contributor
Solution
Re: Max plan
Hi @Cathliamluke
Re: Max plan
Good Morning @Cathliamluke.
Welcome to the community 🙂
How exciting, are you there now?
As @tahirmian has mentioned, you can use your phones in America at no extra cost for calls, texts and data.
Let us know if you have any further questions.
I hope you have a great time 🙂
Jon
