by gec6156
Max plan roaming- are Cayman Islands included?
Hello. New to the forum. Just signed up to a Max Plan for my son. Wanting to establish whether roaming is included for the Cayman Islands. A link to info would be appreciated. Thanks
by Ace Contributor
Solution
Re: Max plan roaming- are Cayman Islands included?
@gec6156
You can check here http://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/roaming-costs/countries/cayman-...
And it is not included in your free roaming allowance.
Many Thanks
by Ace Contributor
Solution
@gec6156
Many Thanks
@gec6156  Please read THIS it will tell you what other countries are covered by the max plan.
