by philip751 Investigator
Max plan not working in Mexico
Even though I have a max plan I have not received any confirmation that my phone will work in Mexico without having to pay extra.
10 REPLIES 10
Re: Max plan not working in Mexico
Did you receive any Welcome msg on entering Mexico? Maybe EE don't know you gone roaming. Did you enable roaming on your a/c before you left UK?
Hi,I did not receive a welcome message and I have been to Mexico before when it worked. All I have done since then is upgrade my phone.Phil Sent from my Samsung Galaxy smartphone.
Check whether you have Roaming enabled in your MyEE a/c under Manage Device. If not, try to switch it on. If it won't let you you will need to call CS to do so.
Hi @philip751,
Welcome to the EE Community.
If you try to load a webpage, are you redirected to purchase an add-on or does the page load successfully?
Hi,If not on wifi yes.PhilSent from my Samsung Galaxy smartphone.
Hi @philip751,
If you are not directed to the add-ons page when browsing the internet over mobile data, it means your inclusive roaming in Mexico is working.
Have a great holiday. Smiley Happy
Hi James,I get the redirect when I am not on mobile internet.  I wish I was on holiday! :(Phil Sent from my Samsung Galaxy smartphone.
Hi @philip751,
Just to confirm, your mobile data is working fine but you can't connect using WiFi?
Hi James,No.  I admit that I have not tried mobile data yet as I do not want to risk incurring charges. I can connect to wifi no problem.PhilSent from my Samsung Galaxy smartphone.
Hi @philip751,
If your plan doesn't include roaming in Mexico, you'll be redirected to purchase an add-on if you try to use mobile data.
You can't be charged for data usage when roaming without purchasing an add-on.
Let me know if mobile data works when you have had a chance to test it.
Recent solutions
