Highlighted
by Investigator
Max plan doesn’t work
Hello,
im in NZ. I called to organise a change to the max plan before I left. Now im
here the phone appears to be connected to Spark NZ but does not seem to be using data. Have checked and data is turned on.
Have turned it off and on again. It still doesn’t work.
any ideas?
6 REPLIES 6
Highlighted
by Investigator
Re: Max plan doesn’t work
Thanks for the suggestion.
had a try and it doesn’t work.
I’ll call Ee when they open in a bit.
thanks again
Sent from my iPhone
Highlighted
Hi @LM4
Log into your online account and ensure you have activated roaming and international calls.
I assume you didn't check roaming was active before leaving the UK.
Highlighted
by Investigator
Hello, thanks for your reply. I checked and they are active on my account.
the screen reads Spark NZ 4G, so it appears to be connected.
i called EE before I left and was told I could just use my phone as normal when in NZ.
incidentally I tried to use a data pack recently in South America and that did not work either. I’ve been through all the phone settings and everything is on.
Highlighted
by Ace Contributor
Hi @LM4 What happens when you try and use data, and go to a site like http://neverssl.com
(It's important to try a non https site)
Either...
It works - there's no problem
You get redirected to the add-on page - roaming works but there's an account issue
Nothing works - either a phone or roaming isn't enabled issue.
Highlighted
by Investigator
thanks again
Highlighted
Hi @LM4
I have sent you a private message for some further information, please take a look and get back to me.
Speak soon, Katie 🙂
