by Nickw
Max plan and sharer SIM roaming allowances
I have a max plan with a sharer SIM added . Will the share SIM user be charged for using the data and texts from the original package?
Solution
Re: Max plan and sharer SIM roaming allowances
Hi @Nickw,
Welcome to the EE Community.
Your sharer SIM will have its own call and text allowance but will share the lead phone's data allowance.
Hope this helps.
Solution
Hi @Nickw,
Hope this helps.
by Kurran Investigator
Hi @James_B
To clarify on this,
Can the shared sim use data when roaming in the 4 additional countries which include US?
Thanks!
Good Morning @Kurran
Yes, you and any sharers will be able to use the MAX Plan in the USA and the other additional countries.
Thanks,
Katie 🙂
