by marvintv
Maritime Help
Hello
Where can i find the Option to buy a Data Ad-On for Maritime (Cruise Ship)
Solution
Re: Maritime Help
Hi @marvintv,
Yes, you can purchase your data add-on when you first connect to the Maritime network.
You'll automatically be redirected to a webpage which will show you the currently available add-ons you can choose from.
Most cruise ships will also have WiFi options available.
6 REPLIES 6
Re: Maritime Help
@marvintv
There isn't one as the maritime network is separate to land based networks. The cost of using your device is here.
by marvintv
Re: Maritime Help
Hello
Thanks. Yes i know but it says i need to buy a data ad-on but which ?
Re: Maritime Help
Hi @marvintv,
Welcome to the EE Community.
When you first connect to the internet on the Maritime network, you'll be redirected to a webpage where you can choose your data add-on.
by marvintv
Re: Maritime Help
Hello
Great. Thanks.
That means i can buy the Data Ad-On Directly on the Cruise ? And you know the Prices ?
Solution
Re: Maritime Help
Hi @marvintv,
Re: Maritime Help
