by Meep87
New Member
Making calls from Spain
My phone won’t make a call from Spain how do I enable it
Re: Making calls from Spain
@Meep87 : If you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150?
Often just rebooting the phone is the simple remedy. Otherwise try logging into your MyEE account online & go to Menu / Manage Device / Roaming Abroad and also Call Abroad and Premium rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
PAYG is auto enabled for roaming. You don't need to & can't do any of the above.
Hi there @Meep87
Welcome to the community.
Has the advice from @XRaySpeX helped you make calls in Spain?
Let us know how you are getting on 🙂
