by Lkroach
MAX plan not working in USA
On MAX plan and when I landed in USA I received the generic charges message- nothing to suggest usage was included in my plan. My roaming is on (I’ve already my phone in the EU a few times this summer) and I can’t see any old travel add ons on my account (I did use the daily charge option last summer in aus. Before getting this new plan). Any advice?
by Brilliant Contributor
Solution
Re: MAX plan not working in USA
Hello @Lkroach
Thank you for taking the time to post today. Smiley Happy
If you browse add-on.ee.co.uk/status on your phones browser (make sure you are using mobile data, not WiFi), this should tell you how much data you have remaining - if it shows you have data remaining, you are on the correct Max Plan, if it asks you to purchase data, you're on the wrong Max Plan.
I hope this helps. Smiley Happy
Solution
Hello @Lkroach
Hi @Lkroach,
Welcome to the EE Community.
That's great advice from @Inyourbox.
Please let us know if you have any additional questions.
Have a great time in the USA. Smiley Happy
by Lkroach
Thank you for your advice. It comes up with saying ‘data in USA’ so seems I am on the correct plan. Shame that wasn’t clear on the initial text message sent! I appreciate your help.
Sent from my iPhone
Hi there @Lkroach
Thanks for coming back and letting us know.
Hope you have an amazing time 🙂
