by navyhatter Investigator
Loss of Data Roaming
I'm working in Norway and up till yesterday afternoon my EE data roaming was fine. Yesterday evening when leaving work I had no data connectivity. Anyone have any ideas. ?
Solution
Re: Loss of Data Roaming
You can use any network that your phone will connect to, @navyhatter.
If we do not have a roaming agreement with an operator, it will not let you connect at all. So, there's nothing to worry about with that.
Chris 🙂
8 REPLIES 8
Hi @navyhatter.
It sounds like you're fully set up for roaming. Please try the steps below to try and get a connection:-
Try re-booting your device
Try turning 4G off in ‘settings’
Perform a manual network search:-
  • iPhone – Settings > Carrier > Toggle Automatic OFF
  • Android – Settings > More Networks > Mobile Networks > Network Operators > Tap OK
  • Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Please let me know if any of that works.
1. Have tried re-booting phone ----- no difference
2. Changed to 2G/3G (auto connect) ------- no difference ------ returned to 2G/3G/4G
3. Phone shows me as connected to Telia N|EE
Thanks for getting back to me, @navyhatter
Could you try the manual network search and trying another available network operator?
Let me know how you get on.
Chris 🙂
If connecting to anyone other than EE's partner (Telia N) would that incure charges ? or would this still be within my Roaming data plan.
Solution
Chris 🙂
I have switched to Telnor N and this seems to have worked. Many thanks.
Brilliant, glad it's working, @navyhatter. 🙂
Thanks for getting back to me.
Chris 🙂
by SandyLoynd
New Member
Had the same problem with no data availability. Sorted by following the above solution too.
Bit of a pain trying to go on and off open wifi networks to get tourist info. Ee obviously has an issue it needs to speak to Telia about...
Nice to do a bit of old skool wandering with a guide book stuck to my nose so bout all lost 🙂
