by Samanthacarrick
Landed in Cyprus but unable to dial out - help!
Hi there have landed in Cyprus but I am unable to make any calls even though I was sent the EE welcome message say I can make calls. Please help!
Re: Landed in Cyprus but unable to dial out - help!
@Samanthacarrick   Did you enable roaming on you account before you left the UK ?
by Samanthacarrick
Hi there yes I did
Sam
Sent from my iPhone
@Samanthacarrick
Have you tyred resetting your network under settings?
EE Employee
Hi @Samanthacarrick and welcome to the community.
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on.
Please also can I get you to try and dial a friend or family member using format of 00447********* and try using data.
Did this work?
Many thanks,
Lee
