by TonytheTeacher
New Member
Keeping Greek carrier not Turkish when roaming?
I'm soon off to Kos for a week. As part of Greece, it's included in EU roaming. However, I've been warned that often a phone will try to connect to Turkey (only a few miles away). Is there a way of avoiding this, or do I need to look out for a particular carrier before allowing roaming? Does anybody know the name of the Greek carrier so I can make sure I only select this?
Thank you!
by Profile closed
Not applicable
Re: Keeping Greek carrier not Turkish when roaming?
You just need to turn off the 'automatic' option in your handsets carrier / network settings and manually select the Greek mobile network you want to use.
Hi @TonytheTeacher
Welcome to the community.
@Profile closed has given some great advice.
See our getting ready to use your phone abroad post for full details on getting ready to use your phone in Kos.
Have a lovely time 🙂
