by RC0013 Investigator
Just bought travel data package for USA but how do I use it
 Just bought travel data package to use maps etc in USA. How do I use it as nothing happened I try to use maps but do I put data roaming on as it’s just swirling & timing out.
8 REPLIES 8
Re: Just bought travel data package for USA but how do I use it
@RC0013 Yes , you need to turn Data Roaming ON
Yes my roaming is on and it worked in the uk. It’s only the maps I want so thats the only thing I have turned on.
All I get is request timed out but it’s using up data. But map being able to see a map is a waste of time.
If on contract, did you activate roaming on your EE a/c before you left UK?
Try logging into your My EE account online & go to Menu / Manage Device / Roaming Abroad and also Call Abroad and Premium rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
Yes I’m on a business contact. already in the USA and the hire car has apple play so would be easy to use apple map as a sat nav and cheaper.
Good Morning @RC0013.
Did you manage to check if roaming is active in your MyEE Account as @XRaySpeX suggested?
This would need to be active to be able to use data abroad.
Jon
No site under maintenance
Thanks for getting back to us @RC0013.
I've sent you a private message to get some more information from you.
Please take a look and get back to me.
Jon
