by Andrew08
New Member
Just arrived in US - phone does not work for calls. Switched on and off. text ok
Can't call to get help - no option but this forum
Re: Just arrived in US - phone does not work for calls. Switched on and off. tex
Did you activate roaming on your MyEE a/c before you left? Presumably not. Having a roaming allowance does not auto enable it. You may still be able to in your online a/c under Manage Devices. If not, you will need to call EE. Use the landline nos. in my sig.
EE Employee
Good Morning @Andrew08
Welcome to the community! Smiley Happy
If your texts are working ok then roaming will be active on your account.
What happens when you try and make a call?
Have you tried doing a manual network search in settings?
Thanks - Karen. Smiley Happy​​​​​​​
As long as OP means sending texts are working. I allowed for the possibility that only received texts are working.
