by insch Investigator
Japan - can I keep adding add-ons when roaming?
I'm going to Japan for two weeks and want to minimise roaming costs. I know that I can add add-ons but if they run out can I just add another one? And is £6 per day for 150MB the best possible deal for data? I am generally quite happy with my 10GB monthly limit in the UK so I am not a hefty data user but I might need more in Japan.
Solution
Re: Japan - can I keep adding add-ons when roaming?
You don't need to keep adding add-ons.
Once you opted-in for the Travel Data Pass it only kicks in on the days you use data.
The Calls & Texts Anywhere add-ons last a month anyway.
Solution
Thank you
"You don't need to keep adding add-ons."
What about if they run out over the time I am there - do i just buy an additional one?
"Once you opted-in for the Travel Data Pass it only kicks in on the days you use data."
So I opt in at the start of the trip and then will pay £6 for every day I use data?
Yes, that's correct.
Thank you
Recent solutions
