Highlighted
Isle of Man outgoing calls
Hi
I'm in the Isle of Man but can't seem to connect to UK landlines or mobiles I have an everything package with data calls and texts on .
I can ring Isle of Man mobiles and receive IOM landline calls.
Highlighted
Solution
Re: Isle of Man outgoing calls
@Joshalixkatie  Are you putting 44 or +44 instead of the 0 at the start of the number ?  You are roaming at present.
Highlighted
Solution
Highlighted
Cheers Chris B
That's solved the landline problem.
Are mobiles the same do they need 44 in front Instead of 0
Many thanks
Highlighted
Yes.
Recent solutions
