Highlighted
Is there a way to get Roaming set up once you are abroad, please?
Highlighted
by Ace Contributor
Solution
Re: Is there a way to get Roaming set up once you are abroad, please?
You can set it up using the MyEE app.
- Current Usage -> Control, then you should
the following screen:
Make sure that both Use phone abroad and Make international & premium rate calls are switched on.
W
Highlighted
Is there a way to set up roaming once you are abroad please?
Highlighted
by Ace Contributor
Solution
W
