by Vicbake
Is there a time limit on using max plan outside EU?
Solution
Re: Is there a time limit on using max plan outside EU?
@Vicbake: Yes, no more than 2 months in any 4 month period. The same goes even within the EU.
Solution
Welcome to the community, @Vicbake. 🙂
Where are you off to?
Do you mean within the additional 5 inclusive countries?
by Vicbake
It’s my daughter, she off travelling for 12 months. Canada, USA, NZ, Australia & Far East on the way back. So she’ll be out of the country for 12 months, but even if I put her on a max plan, she won’t be able to use it for long!!
That sounds really exciting @Vicbake!
As @XRaySpeX mentioned, there is a limit on how much you can use the plan when you're abroad as you need to be deemed to have a stable link back to the UK.
Jon
Yes, EE plans are meant for users who are normally resident in the UK, not for being abroad for long periods.
