by _richardaustin
New Member
Is roaming free in Norway?
Solution
Re: Is roaming free in Norway?
@_richardaustin   You can use your tariff allowance while in Norway,  just text ROAMING to 150 before you leave the UK,  you can do this now if you wish.
you can use up-to 15GB of data per month while in the EU if your tariff has this or more.
Solution
